i need cam,lifters,anything else
  • i need cam,lifters,anything else
    iam over hauling my motor and i want to ive it ome jump o what ever pars anyone has please let me know iam interested thanks
    15862929627 if u want to talk more details
    what type of engine? Youll need gaskets, oil pump etc...you leaving the bottom end alone?
      Originally posted by 95camarolt1 View Post
      I am over hauling my motor and I want to get a jump on whatever parts anyone has. Please let me know. I am interested.
      Thanks
      1-586-292-9627 if you want to talk more details
      fixed
        pushrods
          good job fred...and after looking at your username im assuming its a lt1?
            yes gaskets
            yes iam doing the lower end i omost got the motor out but dam there is alot os shit to take off lol yea i do need some gaskets i thinking of ordering from summit
              Depending on your budget, but it looks like you're gonna need a lot more than you originally planned. If putting in bigger cam, you need new springs, rockers(buy Comp Cams Pro Magnum 1:6 for 7/16 stud), rocker studs(ARP), maybe lifters, push rods, retainers seals, should have heads ported, headers, y-pipe, bigger injectors, Ported intake Manifold, Larger Throttle Body, larger capacity fuel pump to feed it. You can build the bottom end, but increasing air flow is where the horse power is increased.
              sigpicWe live in the Land of the Free and Home of the Brave. If you're not willing to defend her, you're not worthy to live here, so get out.
                you may not need all of this just yet, but i agree. i think youre gonna end up needing more stuff than you originally planned. aside from that, it just doesnt make sense to take a lot of that stuff off without replacing it
                  I have a brand new set of the "blue stripe" Comp Cams 130# valve springs, should you need them. Set of 16. Got them off Ebay and my project took a different direction. I'll let go of them for $70 + shipping. Never been compressed, never ran.
                    I have a good set of lifters 30.00.
                    Also have a brand new Comp 306 cam 175.00
                      So....for less than $300 you have a complete cam setup, minus rockers. Not a bad deal. My rockers were more than that alone.
                        Are you doing a stock rebuild?
                          can i use that cam on stock fuel pump,rockers,pushrods
                            Yes.
                            It's for an LT1 so there shouldn't be an issue.
                            Also have a stock K-memeber if you need.
                            May need a spring upgrade though.
                            I have a few stock LT1 cams if you would like.
                            25.00
                              I have a stock cam from a 93 camaro z28...32,000 miles,lifters,push rods,rockers,springs,locks and retainers...all for 125.00
