If you have all the "Correct" Parts it should set right in there with no problems. How much is it worth to you for somebody to come help set it in there?
3rd gen v8
here is some more. the engine is one i tried to put in the car and it would not fit it is also the 283 for sale. the transmission is what is going in my car when i get the engine in thereAttached FilesLast edited by beardy2; February 25th, 2008, 05:28 PM.
Originally posted by WMCC Gary View PostIf you have all the "Correct" Parts it should set right in there with no problems. How much is it worth to you for somebody to come help set it in there?
hey i would greatly apreciate help but until my engine and transmission sell i dont have much money. i planed on selling them to buy an engine from a 3rd gen. if had money right now i would pay you if wanted to come help but right now i am broke.
That's easy...get an F-body oilpan. You probably have a large truck pan or something on there....get the right pan and bolt the mounts where they belong and it will drop right in.Originally posted by beardy2 View Posti tried that and it wont bolt in because of the oil pan sits on the kmember but your right it is in the perfect posistion when its down theresigpicTurbo Charged LS1/T56
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
He has an LS1 in his car so measuring his won't matter anyway. I would put the stock mount brackets back on and get an fbody oil pan. Should drop right in as previously suggested.Originally posted by beardy2 View Postthe front of my oil pan is about 2 inches how big is your oil pan you dont need to go measure just an estimate
with the stock mounts on the oil pan is like 5 inches from the engine cradle so with those mounts it would not really matter what oil pan is on. the problem with those mounts the engine does not sit low enough and wont line up.
So by adding tubing to the mounts it sits lower?Originally posted by beardy2 View Postwith the stock mounts on the oil pan is like 5 inches from the engine cradle so with those mounts it would not really matter what oil pan is on. the problem with those mounts the engine does not sit low enough and wont line up.
Seriously put ALL the STOCK mounts on and it will fit. If you need a pan let me know, I have 1 or 2 out of a fbody that will work.Western Michigan Camaro Club ~ President
here is a pic of the origanal mounts. the mounts that i made sit about 2 inches lower then these ones.Attached Files
You are making this WAY more difficult than it really is.
