I figured I'd write this up to help some people who are new to forums. We all had to start somewhere. I'm going to write up both ways to do this.
The tutorial on how to attach a sig can be found here.
First I'm going to show how to attach an image to your post using the "Attachment" feature.
Once you have typed out your post and are ready to attach an image
-Scroll down and click on "Go Advanced"
-Scroll down and click again to where is says "Manage Attachments"
-This will open a new box.
-In this box click on "Browse" and then navigate to where the file you want to attach is located on your computer.
-You can select 1 file for each box so you can upload a total of 5 files at one time.
-After you have selected your file(s) click on "Upload"
-After you have clicked on "Upload" the window will load and when it's fully attached the file it will let you know that the file is attached.
-Once you have uploaded all the files that you want, go ahead and close the box and if you don't have any changes to your post you want to make, go ahead and click on "Submit New Thread/Submit Reply" Once your screen reloads you should see the files you attached, attached to your post and look similar to this.
Ok that was how to attach a file via the Attachment feature. Another way to do it is to Hotlink the image to your post so that it shows up just like the images above instead of inside a box.
-To do this you first need a place to upload your files too. There are lots of free places where you can upload images too. For this tutioral I'm going to use PhotoBucket.com
-After you make an account and upload your pictures you want to click on the box under the image and it will automatically copy the image to your clip board. Make sure you get the "Direct Link" code if you plan on using the "Insert Image" button or click on the "IMG Code" link if you just want to take that link to put in your post
-Next you will want to start to make a post like you normally would. Then when your ready to attach your image you take the code you copied from PhotoBucket and you can either click on the "Insert Image" button or use the img codes.
-If you click on the "Insert Image" button it will open a new box and this is where you'll put the image address that you copied from over on Photobucket.
-Click "OK" and it will insert the image right into your post in the last position your had your text cursor.
-Once your done inserting your images and ready to post, click on "Submit New Thread/Submit Reply" and it will reload the page and you should see your post similar to this.
-The other way to attach an image to your post is to use the img tags around the images address which will then attach it directly to your post and not load the image until you hit submit which is helpful if your uploading huge pictures or if your writing a tutorial.
That's it! If you have any question please feel free to ask.
Thanks for the comments guys.
