94 z28 need advice
  • 94 z28 need advice
    Hey guys I'm trying to get some advice on what to do to my car I have the motor and trans out and got all winter to build it thanks for any help the car is a 94 camaro z28 it has a cold air intake bbk crank pulley ac delete and true duals dumped before the axle still need headers
    What kind of budget are you looking at?
    We're real good at spending other people's money...
      Probaly around 4000 maybe more hope
        LS swap it.....
          4000 or more = LS...or a shit ton a JR bacon burgers...cant go wrong either way.
          Sent from my DROID4
            Originally posted by c0ncEpT View Post
            LS swap it.....
            Sent from my DROID4
            Yes, that would be the easy way out...
              Yea, we don't want to clog those arteries
              Sent from my DROID4
                LS swap....pretty much the standard answer for anyone seeking advice on the LT1 around this site. May I suggest LTXTech.com..... Lots of options for the LT1 and it can in many cases out perform the mighty LS....
                  id rather buy another car or jam a bigger motor in it so no ideas on heads cam or anything?
                    Buy a package kit from Elliot's Port Works, Advanced Inductions, Trick Flow, etc and bolt go from there.
                      What are your goals for the car? Street driving? Drag Racing? Road Racing? Autocross? Pulling 5th wheel trailers?
                        mostly street driven and go the track here and there would like to hit high 11s low 12s
                          auto or 6 speed
                            auto i plan on taking it to a buddy of mine to have him rebuild it and do a shift kit
                              a h/c 383 should get you there pretty easily... probably doable with just heads/cam and a stall.
