ok so I was going thru my engine bay and I found a connector that I didnt have plugged in.......In the picture connector A and B both fit in connector C but I'm not sure where the other plug would go and would that cause the high idle over a small vac line?Connectors Labeled.jpg
new from Fair Haven, MI need someone to help with car
InActive Member
- May 22nd, 2011
- 406
- Josh McCabe
- 1998 Camaro Z28 LS1
- Troy, MI
- I'm a Technician at Hamilton Chevrolet
man i wish u were a bit closer so i could come by n take a look... i used to know the 3.4 inside and out n im sure if i looked under the hood i could figure it out!1995 Firebird Formula (Sold but not forgotten)
1998 Camaro Z28 LS1
2004 Trailblazer LT3 i6 4x4 (wifes ride)
InActive Member
- May 22nd, 2011
- 406
- Josh McCabe
- Troy, MI
lemme see if i can find some pictures on line or get ahold of the guy i sold my 3.4 too. he only lives down the road from me so maybe1995 Firebird Formula (Sold but not forgotten)
1998 Camaro Z28 LS1
- Lowell, MI
- Meat Processor
post the wire colors of each connector
If it were an LT1 I'd be able to help so much more.
- Lowell, MI
- Meat Processor
Connector C is your crank sensor. You definitely want to figure out which one that plugs into
I have a feeling you have a some connectors in the wrong places.
do you know anyone that has the 3.4 on here as well? if I can get a bunch of pics i could figure it all out prolly.......but im thinking im like the only one with a v6 on here haha......im not having any luck pulling up pics on the net for the area i need
Welcome. An open vac line will cause a high idle so you will need to block it off or figure where it goes, you can just forget about it since it's behind the intake... If it's for sure jumping in idle around your injector it hast to be a messed up o ring or cracked injector, the carb cleaner/starting fluid won't lie.
Hope you get it figured out!2002 Z28 Camaro A4
- Lowell, MI
- Meat Processor
Alright, lets try to break it down.
ICM - all three plugs present?
On the passenger side of the engine block there is a 3X crank sensor. That should be plugged into the ICM.
There is a 24X crank sensor up by the crank pulley. That should have green, black, and red wires. From what I've read the connector that plugs into that should have light green, blue with black stripe, and the yellow with black stripe wires coming out of it.
The cam sensor (connector C I assume) up front of the engine, above the water pump and just in front of the intake, and should also have green, red, and black wires. That plugs into the connector with red, red with black strip, and black with white stripe wires (connector A)Last edited by hoogiesngrinderz; May 6th, 2012, 11:21 PM.
- Lowell, MI
- Meat Processor
And I do agree with Michael, time to tear it apart and try it again. I always put a little bit of petroleum jelly into the injector bores and around the o-rings before install. It helps things go together and helps with keeping it air tight.
