At the time I had an A4 with no plans for getting a TC. I also wanted driveability. I am really happy I didn't go bigger. I think it's still a good driver and not so much a strip or weekend only car which was my goal. I still wanted to cruise with the top down with the kids and not have them smell like gasoline when we were done. The wife hates that.
Hopefully, I can catch some of the meets this Summer and talk cars.
Jeff
understandable! I like the smell of unburnt gas fumes a little more than the average person so I dont mind a little overlap
are you still running a 3.23/2.73 gear behind the T56? Ive read the 503 drives almost as friendly as stock, especially with a shorter gear behind it.
The car was originally an A4/2.73 car with the 110 speedo and the non z-rated tires. The first thing I did back in the 90's was add a Borla catback, 3.42 gears with a Torsen Diff., and remove the speed limiter. The car stayed like this for about 8 years before I did anything else.
I am still running the 3.42's so I never have known what the t56 feels like behind anything else. I am going to 3.73 shortly though. Mainly because I need to add the correct ABS reluctor ring to the 3 series diff so my ABS works again. I figure while I am in there....
94 Z28 Vert. A4->M6, Pro 5.0 Shifter/Short stick, Mccleod 7500rpm disc w/ Ram Alum flywheel, 3.42 gears, CAI, XE 224/230 .553/.561 lift w/ 1.65 RR's, LE Stage 3 Heads, 30lb SVO injectors, JetHot LTs, X-pipe Duals, LT4 Knock Module, Personal Tunercat PCM Tune. College, Grad school, and Med School Loans: payment countdown only $272,000left. 8-OInstall pictures
cool, yea the 3.42 is a good gear for the 6 speed. Just out of curiosity did you notice a difference switching to the torsen posi?
