87 bird w/ 307?
  • 87 bird w/ 307?
    I was wondering if the interior from a 87 bird is the same as a 92 bird? Specifically if the top dash is the same? I found a 87 bird w/ a 307 swapped in for $400 so it would make a good parts car if the interior parts will swap over...
    '96 Camaro RS - project
    '97 Silverado Z71 - DD
    '89 Suzuki GSXF 750
    Some stuff is the same, some is different.
    The dashes should be the same.
      Ya should be the same for the most part.
        Is it a 307 Olds motor or a really old 307 chevy?
          I'm guessing Chevy...the Olds has different motor mounts...that would be a pain...
            Originally posted by 81DaytonaPaceCar View Post
            ....The dashes should be the same.
            Actually I believe thay are different.
            — Thomas Jefferson
              Well that's what I was thinking too but I've seen people do stuff like that because that's what they have.
                I thought the changeover year was 87...might be 88...
                  I was thinking it was 90.
                  — Thomas Jefferson
                    3rd Gen firebirds, yeah, I got no clue.
                      After some brief investigation, looks like the dash shells were the same 82-92...gauges look like they differed more.
                        I just need the very top "platform" i'll call it...looks like it will fit then...
                        I dont know what kind of 307 it is...I'll give the guy a call tonight (I'm assuming it's a olds because there a dime a dozen and shit, I've never even seen a chevy 307)
                        400 not a bad price then?
                        '89 Suzuki GSXF 750
                          Shouldn't be if there's some stuff you can use off it.
                          The dash place I found wanted $260 for the dash alone...no gauges. Might want to double check to be sure on compatibility.
                          And check out the other 307 thread...
                          http://www.mifbody.com/vbulletin/showthread.php?t=9999
                            Yea...I NEED seats, upper dash pad...and could use some consoles and door skins...
                            I'll see if i can get it for 300
                            '89 Suzuki GSXF 750
                              The interior looks different in parts...but the dash pad looks similar...
                              so...do you think I could at least part it out for 400?
                              '89 Suzuki GSXF 750
