Got some quotes today from Reichert Engines....
As far as the short block work goes:
-bore cylinders .030 over
-press rods&pistons
-install cam bearings
-install soft plugs
-hot tank/flux test
-line bore
-balancing
-grind block for clearance
-Eagle 13005 rotating assembly
I got a price of $1370, which doesn't seem too bad I guess. This would make everything ready to bolt in, and I'll do that back at the house. Cam and heads will be extra of course
This guy was 4th in the nation in top alcohol dragster this year, so I trust he knows what he is doing 8)
-press rods&pistons
-install soft plugs
-hot tank/flux test
-line bore
-balancing
