1991 Z28 Winter project
  • 1991 Z28 Winter project
    Well, I thought I should post some pics while I'm getting started here, so I can have memories and scrapbook and stuff...hehe, just kidding.
    Anyhoo....here's my core. It's a 350 out of a whacked '89 Suburban,so it was already built for torque 8)
    Blarg! The driver's seat is ripped up! Dog attack or something like that. Maybe I'll get luck and find another one, because I can't find truly matching covers. A new headliner is going in as well.
    The paint is sundamaged in spots and peeling in others....typical FL car. That gives me an excuse to repaint I'll probably stay with the royal blue metal flake, and add a touch of pearl.
    Other than the seat and the headliner, the interior is in really nice shape.
    I recently found a dashpad to replace my cracked one, so I'm excited about that.
    Anybody got one of these? It's a 1991 Camaro service manual.....maybe it will come in handy someday 8)
    Ok....I haven't decided on any specifics yet, but this is the general plan so far:
    -build 383 out of spare 350 block
    -rebuild 700R4 to a beefy state
    -install weld-in subframe, wonder bar, panhard bar, etc.
    -upgrade TPI with mini-ram
    -repaint
    -interior work
    ....almost in this order I guess, hehe.
    I'll be sure to update as the situation unfolds. I look forward to your creative input.
      you should so do a 4th gen seat conversion. leather seats like the ones in my car would look soo good in that thing.
      my seats:
        How about you just give me your seats Joel?
          probably the same reason I wouldnt just throw you the keys and title to my car
            Wow that car is in pretty decent shape! shoulda seen mine! Two words: Stolen Recovery!
              But you want to, you are just in denial
                of course I want to, but I want to keep it for myself even more
                  I was gonna say the same thing about the seats. 4th gens will complement it very nicley. Other than that it sounds like you have your time occupied good luck with it all.
                    Check out the RPO codes on the inside of the center console and see what kind of goodies you have on that car. Hopefully you have the G80 or G92 rearend
                      Ok, so I got kinda bored and looked up almost all of them Hey, it doesn't hurt to know your car.....
                      Search Results Page
                      RPO Code Description
                      AJ3 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
                      AM9 SEAT, RR, SPLIT, BACK, FLDG
                      AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
                      AU3 LOCK CONTROL, SIDE DR, ELEC
                      A31 WINDOW, POWER OPERATED, SIDE
                      A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
                      B18 ORNAMENTATION, INTR, DELUXE
                      B34 COVERING, FRT FLOOR MATS CARPETED INSERT
                      B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
                      B84 ORNAMENTATION, EXTR MLDG, B0DY SIDE
                      CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
                      C49 DEFOGGER, RR WINDOW, ELECTRIC
                      C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
                      DC4 MIRROR I/S, R/V, TILT, DUAL READING LAMPS
                      D3W GEAR, SPEEDO DRIVEN
                      D34 MIRROR, VISOR VANITY
                      D35 MIRROR, OUTSIDE REAR VIEW
                      D42 SHADE, RR COMPT SECURITY
                      D8N SENSOR, VEH SPD
                      D81 SPOILER, RR, AERO WING
                      E5Z SPEEDOMETER ADAPTER (DELETE)
                      E9Z SPEEDOMETER KEY (DELETE)
                      F41 SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
                      GU2 AXLE REAR, 2.73 RATIO
                      G80 AXLE POSITRACTION, LIMITED SLIP
                      IPC TRIM- INTERIOR DESIGN
                      J41 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
                      K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
                      K68 GENERATOR,105 AMP
                      LB9 ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
                      MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
                      MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
                      NA5 EMISSION SYSTEM, FEDERAL, TIER O
                      NP5 STEERING WHEEL, LEATHER WRAPPED
                      or LEATHER WRAPPED, STEERING WHEEL AND SHIFT KNOB
                      N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
                      N96 WHEEL, 16 X 8, CAST ALUMINUM
                      QMT TIRE ALL, P235/55R16/N BL R/PE ST TL AL2
                      T96 LAMP, FOG
                      UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
                      UN6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
                      UQ1 RADIO PROVISIONS, FOR STEREO
                      U79 SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
                      VAN ASSEMBLY PLANT, VAN NUYS, CA
                      VK3 LICENSE PLATE, FRT MOUNTING PKG
                      V73 ANTENNA, FIXED
                      1SC OPTION PACKAGE 03
                      17P WHEEL COLOR, SILVER (91)
                      19C TRIM COMBINATION, CLOTH, BLACK (C) (91)
                      199 SEAT BELT COLOR, BLACK (91)
                      24Q MOLDING COLOR, BRT BLUE MET {91)
                      6XU SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
                      7XU SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
                      8NL COMPUTER SELECTED REAR LEFTHAND SPRING
                      or SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
                      or SPRING, COMPUTER SELECTED, REAR, LEFT HAND
                      9NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
                      or COMPUTER SELECTED REAR RIGHTHAND SPRING
                      98U PRIMARY COLOR, EXTERIOR, ULTRA BLUE MET (91)
                      So yes, g80 limited slip 8)
                        I like the look of the 4th gen leather seats...charcoal would probably go good with my interior....what is involved with the conversion process (manual seats) and where should I start shopping?
                        I take it that 4th gen seats are still available new?
                          Look on ebay or other larger forums. Don't know if you can get them new but used will be cheaper and should be able to find soem in great shape.
                            theyre a direct bolt in unless your switching from non-power to power seats in the conversion. If you upgrade to a power seat you will have to do a bit of fabbing on the electricals.
                              Well that's good to hear....it definitely expands my options while shopping for seats
