TPI performance
  • TPI performance
    anyone know any aftermarket TPI specific websites or vendors
    what you looking for?
    5th gen Camaro V6 Forums
    http://www.bowtiev6.com
      TPI is fiarly limited. What do you want to do.
        go fast mostly valve train and induction later i would like to do some lower end work. its an 89 does anyone know if it's a roller motor
          Check these web sites out for TPI
          www.tpiparts.net
          http://www.azspeed-marine.com/index.html
          www.tpis.com
          www.aztpi.com
          and the rest of your speed part needs are basically standard gen 1 SBC stuff.
            TPI will work if you want a low revving torque setup. I ditched mine because I wanted the option of having more of an RPM range, so I'm going to get a retrofit LT1 from www.lt1intake.com. You will gain a lot of HP with only a small loss in torque.
            But that was just my decision
              87 and up are roller motors
              -Homer Simpson
                There are some that are set up for a roller, but have a flat tappet. The L98 I had was like that when I tore it apart. No modification needed for the new roller to go in, besides giving it a spider and dogbones.
                  get a TPI, then down the road swap on a Holley Stealth Ram.
                    Holley Stealthram Intake ,Some decent heads Brodix 23* -8 comes to mind, Mild camshaft, good headers and pray the rear stays together.
                    Sean
                      -Homer Simpson
                        I have recently come accross this TPI set up which looks pretty cool.
                        http://www.affordable-fuel-injection...-injection.htm
                        I am pondering on this or going with the Big Mouth TPIS manifold and the existing SLP runners I have, then porting out my upper plenum.
                          If you really want to stay with TPI, I would suggest the Holley Stealth Ram. The stealth ram also works well with heavier breathing parts you may want later on when $ permits (heads, valvetrain, headers, etc). However IMO, TPI is a pretty poor system to modify. While it's fairly reliable stock and produces nice torque, if you end goal is all out performance then I would look towards different fueling (carb, stand alone, etc). The cost of making a high output tuned port system can get pretty high compared to other setups...
                          Don
                          86 IROC-Z, my first car
                          87 VW scirocco, track weapon
                          99 Audi A6 avant quattro, DD
                            Edelbrock makes a nice set up, along with a ported plenum. All depends on power you want to make.
                            I like my set up a lot. Edelbrocks high flow intake and high flow runners to match. I can even port everything even more if I wanted to.
                            But that will wait for the 350 when I tear it all apart again.
                              I don't know my TPI car seems to run pretty well.
