As you may or maynot know, last week my car's radiator and wheel bearings took a dump and i had to be towed home. I have an issue now that i have the front splitter (which compleatly encloses the underside of the nose) the tow truck driver was having trouble finding a spot to wench it from. He wanted to pull it from the sway bar but i said no to that. He was eventually able to hook it onto the holes in the jack boxes behind the front wheels....
Question is this... Can pulling it from the sway bar be ok or will that bend and cause issues? If its a bad idea (which i think it is) has anyone ever installed a "tow hook" to the frame and if so, where and how did you mount it. Heaven forbid i should need a tow in the future but should something happen i dont want to have to argue with the driver on where to wench it from...
