I came across a Holley Stealth Ram intake this summer for cheap and I am currently installing it. Ive run into a couple snags and I am wondering if anyone here has run or is currently running with this intake. It looks like I need a new water neck and upper hose, not sure what one to get or rather what one I need and its looking like the stock fuel lines are not going to be a direct fit either, so Ive been reading.
HSR swap
HSR swap
1989 Stock L98, Holley Stealth Ram intake, Hooker Headers, GMMG cat-back with cat-delete, #24 Bosch D3 Injectors -
Go to your local performance shop like mazzas and get fuel hoses. Anyone should carry a mr gasket water neck that fits the intake. I walked into the back and just picked up a rad hose that looked correct. If you want detailed information like AJ said, TGO has it all. If these small tasks become a challenge, I would suggest against the swap. These are the very minor details. Hopefully the car runs good afterwards, else good luck getting it tuned.
yea tuning on the old PROM chip is going to be the hardest part of the task, specially finding someone who can do the tuning properly'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
The biggest problem with the HSR is using a MAF setup. Stock heads might not be so bad, but once you get nice heads like AFR or similar you really need to go to a 7730 ECM or aftermarket.
Whats wrong with a MAF setup? GM High Tech mag years ago used an 86 camaro with a 355 on a stock computer and ran a 12.6 just by messing with the timing and fuel pressure. After a custom tune they ran a 12.229.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
True potential of the HSR is bottlenecked by the MAF.
HSR with a good set of heads will easily flow more than the MAF is cable of, even descreened. I'll have to check with my friend, Brad, but I think he made over 50 rwhp by swapping his 87 IROC (400, HSR, AFR 195, small cam) going to 7730
Thats a serious gain in power. Though not sure what the gain would be if I switched seeing I have a stock cam and heads for the time being.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
If it's under the max flow of the MAF, it can work.Originally posted by Blue_Thunder View PostThats a serious gain in power. Though not sure what the gain would be if I switched seeing I have a stock cam and heads for the time being.
Even then, the MAF table can only read so much. Usually maxes out early, but PE fueling can be dialed in. Brad was pushing over 400 at the wheels IIRC after the ECM swap.
Originally posted by hoogiesngrinderz View PostIf it's under the max flow of the MAF, it can work.
this guy ^ knows what he is talking about.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
