Has anyone swapped a 4th gen rear end into there third gen? I am about to do this. I am buying new wheels but I am not sure what offset and backspacing I would need? Any help would be great.
4th gen rear end
Enthusiast- January 1st, 2009
- 342
- Chris
- 1987,Chevy,Camaro(IROC)
- Jenison, Mi
- Gentex production maintenance
I did, if your planning on running 4th gen or corvette wheels they will fit no problem, You'll still need to run adapters up front 2".
what are you doing with you stock unit ?'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- 342
- Chris
- Jenison, Mi
Is there a specific reason you're choosing a 4th gen rear end? Other than the brakes, there is not much advantage in swapping. You can get a stronger Ford 8.8 or even a 67-81 GM 10 bolt (8.5") and your total cost would be negligibly more and would yield a much stronger results...............____ .......
________|___\____
|__(O)__|____|_(O)|
HEI distributors are pointless.
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
- 342
- Chris
- Jenison, Mi
Only based on its cost, availability, and bolt on application.Last edited by sweet_87_iroc; June 30th, 2014, 08:44 AM.Air Force/Afghanistan veteran
1987 Iroc camaro Supercharged 5.3
2012 Toyota tacoma
well they are out there, could even find one free too, shoot me a price on your stock unit with some details. If you want to upgrade your brakes on the stock unit or 4th gen, I know a local guy.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
