So the moral of the story here is to find the ecm and start eliminating lol
clutch and wiring questions
- Lowell, MI
- Meat Processor
A sharpe blade and a sharp mind are two must haves when it comes to pulling wires!
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
how are some wires the same??? and the carb is tapped into something right now just not sure what but good to know all i need is a fused source. heat and ac are part of the body harness tooright? im trying to find an ac delete panel, well i know were one is just he needs to send me it lol. but id like to keep heat at the least.Originally posted by hoogiesngrinderz View PostGauges do not operate through the ECM on third gens. IIRC some wires are in the same harness though. Holley electric choke just needs key on power, find a fused source.
Do you have a hydraulic or Z bar clutch? I forget when the changeover was.
i have a reservior next to my drake booster and everything does that mean hydraulic?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
- 3000
- Tyler Porter
- student
- Lowell, MI
- Meat Processor
most gauges are wired through C100 (bulkhead) but some important wires run over to C207 (these wires run in the engine harness)
Reverse switch wire...dark blue. Electric fuel pump? Power wire for that relay runs through that connector as well.
That was available, Im pretty sure thats what those brass contacts are forOriginally posted by sman View PostWait, so that thing has a power closing hatch? Or did I mis-read that?sigpic
Go BIG or go HOME!
- Lowell, MI
- Meat Processor
The contacts are for the 3rd brake light.
Edit: The outer two are for the 3rd brake light, inner are for the defrost (if equipped)
Usually the gear housing cracks apart on the pull down. A1auto has new ones that fix this issue. I rebuilt the motor in mine, installed the new housing, and had it adjusted in about an hour. It's almost the same pull down setup that the older Cadillac's had. All the switches are in the unit itself.Last edited by hoogiesngrinderz; July 8th, 2013, 05:13 PM.
- 3000
- Tyler Porter
- student
Manual fuel pump.
Link to the 1a auto thing? I dint really mind if I didn't have the power option but as I found out with my 92 it had the power motor and my 85s non power hatch mechanism did bolt in so.im wondering if this style can swap to a non power. The third brake light will be gone soon too. Ill fix the power motor if I have to though
Mike the cluster wires are part of the whole ecm wiring then?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
- Lowell, MI
- Meat Processor
Tyler, I'll have to look at the wiring diagrams for an 86. If you want to come to the west side then I can help...I've done too many east side trips lately.
- 3000
- Tyler Porter
- student
car isnt moveable atm but definitely something id consider in the near future.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Dohhhh
