clutch and wiring questions
    So the moral of the story here is to find the ecm and start eliminating lol
    Go BIG or go HOME!
      A sharpe blade and a sharp mind are two must haves when it comes to pulling wires!
        This is true lol
        Go BIG or go HOME!
          Gauges do not operate through the ECM on third gens. IIRC some wires are in the same harness though. Holley electric choke just needs key on power, find a fused source.
          Do you have a hydraulic or Z bar clutch? I forget when the changeover was.
          how are some wires the same??? and the carb is tapped into something right now just not sure what but good to know all i need is a fused source. heat and ac are part of the body harness tooright? im trying to find an ac delete panel, well i know were one is just he needs to send me it lol. but id like to keep heat at the least.
          i have a reservior next to my drake booster and everything does that mean hydraulic?
          00 Tahoe Z71........Stock
            heres the pics of the rear hatch motor and all its pieces. looks like it will swap over to my other hatch
              most gauges are wired through C100 (bulkhead) but some important wires run over to C207 (these wires run in the engine harness)
              Reverse switch wire...dark blue. Electric fuel pump? Power wire for that relay runs through that connector as well.
                Wait, so that thing has a power closing hatch? Or did I mis-read that?
                  That was available, Im pretty sure thats what those brass contacts are for
                  Go BIG or go HOME!
                    Huh, isnt that something. Never knew that was an option, wonder why they killed it. Must have been problematic?
                      Those brass contacts have always been a problem, I see mini vans come in and the contact plate is corroded and it casues the sliding doors to not close
                      Go BIG or go HOME!
                        The contacts are for the 3rd brake light.
                        Edit: The outer two are for the 3rd brake light, inner are for the defrost (if equipped)
                        Usually the gear housing cracks apart on the pull down. A1auto has new ones that fix this issue. I rebuilt the motor in mine, installed the new housing, and had it adjusted in about an hour. It's almost the same pull down setup that the older Cadillac's had. All the switches are in the unit itself.
                          Dohhhh
                          Go BIG or go HOME!
                            Manual fuel pump.
                            Link to the 1a auto thing? I dint really mind if I didn't have the power option but as I found out with my 92 it had the power motor and my 85s non power hatch mechanism did bolt in so.im wondering if this style can swap to a non power. The third brake light will be gone soon too. Ill fix the power motor if I have to though
                            Mike the cluster wires are part of the whole ecm wiring then?
                              Tyler, I'll have to look at the wiring diagrams for an 86. If you want to come to the west side then I can help...I've done too many east side trips lately.
                                car isnt moveable atm but definitely something id consider in the near future.
