FINALLY got another fbody!!!!!!!!!!!
  • #46
    You can remove the cold start setup and use a memcal chip from an 89, the only year to be w/o a cold start injector (1990 was the start year for the speed density setup and 7730 ecm)
    • #47
      ok ty, I will be posting more as I find out more cause I am bound and determined to drive it this year..
      99 Buick Regal GS- New DD
      SOLD-1967 Buick Skylark
      • #48
        I think I have one or two cold start injectors around if you find it to be clogged.
        If you want to remove it all or just unplug it, I can get you a G1 adapter and program a chip for $50.
        • #49
          I definetly will let you know what I find out and thanx a ton for the help.. since your not that far maybe we can meet up sometime and talk as well.. would love to see your cars, your IROC is gorgeous
          • #50
            Originally posted by hoogiesngrinderz View Post
            on the very front of the intake there should be a CTS (blue arrow) and a cold start switch (red arrow). When the engine is cold, ohm the two pins. It should have very little or no resistance.
            [ATTACH=CONFIG]51269[/ATTACH]
            The injector is located on the driver side of the intake, between the two sets of runners. It is fed by the rear of the rail.
            [ATTACH=CONFIG]51271[/ATTACH]
            ok tested it and it gave me .037 ohms not sure if thats good or bad, but I know the cold start plug the end of it is broken off in the plug socket...
            • #51
              That's a good reading, switch should be fine.
              So the injector plug is broken? Are the wires still making contact with the injector pins?
              • #52
                that I am not sure of, I will take a pic tonight of it and post it so you see exactly what I am dealing with..TY
                • #53
                  The adapter you will need - Moates G1 Adapter
                  http://www.moates.net/g1-memory-adap....html?cPath=64
                  You can go with the GP1 with the ZIF socket for easier chip changes (which I use) but it will not fit under the cover of the ECM.
                  You will need to remove your old chip, pull the blue cover off, attach it to the adapter, then install it as one unit. Moates has a how-to here:
                  http://support.moates.net/g1/
                  • #54
                    well its been awhile, life got in the way as usual.. but I drove the TA to work the other day, I found out that my problem was nothing in the computer or anything like it..
                    I had a busted fuse tab on the ignition fuse.. I feel so damn stupid.. but never thought to even look there...
                    Hoogies hooked me up with some stuff so I will be using it shortly to see if it helps getting it started, still starts hard but I think its the MAF sensor bs myself but will know shortly
