Fuel, Air, spark, compression, and ignition timing. More history of the car is needed. Was it running before the plugs and wires? Could a couple wires have gotten crossed when putting new wires back on, etc? Check the firing order and then double check it.
95' Formula: A4, 3.23'S, K&N CAI, Granatelli MAF, Trickflow Elbow, tune from previous owner. Best 1/4 of 13.91.
An update, car has developed a case of no spark, receiving 12v to coil, with key on, no spark from coil. I'm testing from the red wire going into the coil, is the appropriate place to test?
Dead coil?
And the car hasent ran since 2009. I'm trying to put it back on the road.
fuel at the schrader valve doesnt mean its coming out the injector. check injector for pulse with a noid light.
there should be power on both wires of the injectors. if not check the injector fuses.
alot of times the icm in the dist is bad
You've tested the power wire going to the distributor and you have 12 volts there but no spark getting to the plugs right? Obviously your problem is between the power wire and plug wires so yea a coil is as good a place as any to start. If that does not fix it then ignition control module would be my next step. Or junkyard source a distributor.
Good luck man. I hope you figure it out. I don't have much experience with the remote coil set ups late 80's early 90's GM. However on the older HEI set ups when there is a problem it is usually one of two things, ICM or coil. So again good luck buddy.
