Rear hatch problem NEED HELP PLEASE!
  • Rear hatch problem NEED HELP PLEASE!
    So the deck lid on my car came out of alignment out of nowhere and I've tried everything to try and get it realigned and nothing has worked so far. The left side is fine, but the right side of the deck lid is too high and the rubber stopper is almost all the way down and it's still about an 1" away from hitting. It's starting to drive me crazy please help!
    Is it ok at the roof line?
    if it is use the striker to pull the hatch closed under flush on the left. Then use the left bumper to push it back flush. This should close the right gap.
    If the whole right side is off the hinge probably needs adjusted
      I just checked and it's good at the roof line and i tried using the striker and it didn't make a difference and we tried to adjust the hinge and it's all lined up. I forgot to mention that it has a pull down motor if that makes a difference and I've tried adjusting just the motor and it didn't help with the gap at all.
        Did the hatch open over extended to tweak the right side hinge?
          No, there's no chance of that happening because of the shock absorbers limiting how much it opens.
            Hmmm thats pretty weird, Maybe a hinge is bent or one of the shocks is messed up, rlly not much else for there to be wrong....
            "IROCZ86"
              I got a hinge if u need one
                the latch has up and down play in it so it is adjustable. ive seen my old one actually wear out and scretch everything so that when the latch was at the bottom of its adjustment is was still too high up. if you want to try a different latch mechanism if nothing works you can have mine for free just come and get it
                00 Tahoe Z71........Stock
                  I know it's not one of the shocks and the hinges look fine. We rebuilt the latch mechanism not to long ago and we've tried adjusting it and I didn't see any improvement after doing so, but thanks for all the offers for all parts.
