So, my stock L03 5.0L TBI engine was rebuilt by someone other than myself, then passed onto me when I got the car. Well I've had it running for a while now, and when I'm driving, after heavy load (like accelerating in a spirited manner
) a code 43 is set. The engine looses all power and runs a little more rough.
So, I suspect my harmonic balancer could be spun so timing could be off. I have it timed to 2/3 degrees right now and the vacuum went from 18 to 20, 0 degrees and 2/3 degrees respectively, and it idles smoother and has more power ... This engine has headers, and a stock(ish) camshaft in it. Most likely it's an aftermarket stock replacement, or close to it. I honestly don't know what's going on inside the engine.
So my question is this: Will need to have a chip burned just because I have headers and a possibly modified engine? I'm thinking I might need a new prom burned .... and with that, who can recommend someone to help me get it tuned? I got me one of those USB ALDL cables, but I can't get it working. The engine runs great before the code is set, so my guess is that the engine is running good but needs a tune ... any help is appreciated.
