These have the right offset? They look odd unless they have full pads on them.
6.5" back spacing so I'll need spacers at least on the rear. I think the Baer brakes move the fronts out so I might get lucky and not need another spacer up front. Were your old rims 6.5" bs in the back? Since these are 3-piece I could always order a new outer rim and make a 10.5" wide wheel.
I'm glad I'm not the only one who likes gold centers, if these where mesh it wouldn't even be a question.
I like gold centers on the right car with the right wheel also, but personally I wouldn't use those high-end wheels if that's what you wanted to do. There are many other wheels out there that are better suited to painting/powdercoating in designs that would lend themselves better to gold centers. If I ever do gold on a wheel it'll be the whole wheel.
I personally dont like them, whats wrong with the wheels you have currently? Your car looks perfect I wouldnt change a thing as it sits!
I'm not planning on selling the current wheels, just seeing what 18s would look like on the TA. These were such a good deal I couldn't pass them up. I agree, the 6th spoke is one too many and I'd like them a lot better with 5, but they do look much better in person.
What's a 4th gen wheel back spacing? I bet these would fit.
For a 9 inch wide wheel on the front you will want around a 5.5" BS...that's what my new ones are for the front...keep in mind I also have the additional offset that comes from the rotor hat like you. So you will likely need a 1" spacer for the front.
For the rear you can bolt them on as is but it might look a little goofy. My old 10" wide wheel has a 6" BS and sat just sub flush. My new 12's have 8" BS so I pushed it all to the inside. I'd buy new outer hoops for the rear vs. buying spacers.
