well i fouled out another plug so i decided im need to try something else. i have soem accell's in it right now but ive fouled out a few since i think i was way to rich. what plug would you recommend for a 383 with dart pro 1 aluminum heads
what spark plugs to run
how close is your tune? I run into the 10:1 AFR without fouling champion Copper plugs...
I thought I ran AC DELCO's in my third gen (although i'm not sure with plugs those Al heads take) Sorry I can't be of more help. But tell me more about your tune...
2010 Yukon Denali
1999 Hugger Orange SS M6 - "M6 HOSS"
well its got a 750 holley on it with 66 jets in it. it has a hessitation when you first mash the gas then it screams but it seems to be running good other then fouling out a plug. what else do you want to know
You really gotta get your car's AFR dialed. how much timing do you have? Are you sure the wire(s) is in good shape and you weren't getting weak spark? I'm just throwing out somethings i've dealt with in the past...
you will need to know if the plugs required are tapered seat or not (again, i don't know what type of plugs those Al heads take)... I would start with a trip to Auto Zone.
2010 Yukon Denali
