Battery dead
  • Battery dead
    All of a sudden last night and today sumthing is klling my battery. I didnt leave any lights on Or anythIng and i havnt done anything to it in the last week its just randomly started yesturday nigt that my battery is drained
    "IROCZ86"
    charge it back up and use a test light or a multimeter to see of you have a draw
      got a short somewhere guna try to find it tongiht after work..........
      "IROCZ86"
        A lot of electrical gremlins in that car recently! Good luck hope you find it somewhere easy.
          check the radio that you wired, might have something drawing from that.
            I know right!? Its such BS!! lol and thanks!
            "IROCZ86"
              want to sell it back to me? I didnt have problems lol maybe your not riding her like I use to
                how much? lol
                i hooked up a circut tester and pulled all the fuses and no luck.... Dont know where to go from here
                "IROCZ86"
                  Well with the current market, and you driving it off my lot, depreciation.... I would say 2600.00 lol
                  also look at the alternator, if that is bad, it could cause a bad cell in your battery. Like everyone else said, charge the battery and go from there, take the alternator to murrays have them do a bench test on it .
                    Its brand new, could be a starter issue??
                    "IROCZ86"
                      I have no idea what to do...
                      "IROCZ86"
                        I dont think its a start issue at all. Sure you didnt leave a dome light or something, did u fix the light under the hood ? if you did maybe thats staying on ?
                          Disconnect the Grd (-) side of battery, charge it up. leave grd disconnected over night if battery drops from 12.5 volts after charge to 12 or less over night your battery is bad. If battery is good then connect grd back up disconnect + side put amp meter between battry and cable measure draw with ignition off should not have but 20 milliamps or less. If you have more then pull one fuse at a time to see which circuit is drawing battery down. Its simply a matter of elimination.
                            i did the thing where you pull each fuse yesturday
                            "IROCZ86"
                              with a volt meter ?
