Need opinions on buying O2 wideband setup
  • Need opinions on buying O2 wideband setup
    Well I finally got my Iroc running great after figuring out my two most back injectors were leaking fuel all the time. So I am doing some upgrades later this summer (AFR 195 heads, comp XFI 268 cam, accel base, slp runners.) So I bought 24 # injectors to replace my tired 23yr old 22# multecs. So I put the Bosch III's in and changed everything that was needed in my tune to make everything happy. Wow what a difference. If anyone is running those stock injectors watch this.
    So now I can start tuning for the T56 that I added last summer and I grabbed this the make my tuning alot fast and easier. http://www.moates.net/apu1-autoprom-....html?cPath=64
    Ok here's my question. I want to run a wideband O2 into this thing so I can have my datalogs show AFR. I know some of you guys are running wideband O2 setups and was looking at this setup.http://www.aemelectronics.com/wideba...fuel-gauge-25/ What do you guys think? Anyone got a used one they don't need?
    which ones did you end up getting?
      I got the Bosch III 24# injectors. Stock the L98 had 22# I bought the 24# and adjusted the tune to be happy with them untill I do some upgrades and put the 24# to better use. So far I couldn't be any happier with the way the stock L98 runs.
      Or are you asking about the wideband O2?
