Originally posted by scoutsniper
View Post
Treat that trans gently ...it really isnt a fan of being beat on
There are 2 plugs on the passenger side of the trans ...they are 3/8in i think so just use a 3/8in ratchet with an extention
easiest way to change fluid is to remove the bottom plug and let it drain then remove your console and shifter (make sure everything looks ok there as well since you dont really know how it was driven). Place bottom plug back into trans and remove the top plug. Pour trans fluid into the toploader slowly. Leave the drainpan underneath and have someone tell you when the new fluid starts comming out. Place everything back.. and you are good to go
remember its ATF not gear lube
enjoy ....I have nearly an identical car an i love driving it
