Well, when I stopped at traffic lights today with my foot on the brake, me car would run really hard and then there was a surge of power and my car kinda lunged forward. It was strange. Like I had let up a little on the brake and stepped on the gas pedal, but I didn't. Maybe it's a battery thing, like low power and then a surge of power. Or maybe the timing's off. What do ya'll think?
Robin's issues - never-ending saga...
tranny downshifting? my DD does this too, but im pretty sure its just the tranny downshifting roughlyOriginally posted by Zfenix View PostWell, when I stopped at traffic lights today with my foot on the brake, me car would run really hard and then there was a surge of power and my car kinda lunged forward. It was strange. Like I had let up a little on the brake and stepped on the gas pedal, but I didn't. Maybe it's a battery thing, like low power and then a surge of power. Or maybe the timing's off. What do ya'll think?-Derek-
Downshifting to what? I was already stopped. So wouldn't I already be in first gear? It did it more than 5 times at one light.Originally posted by redfbirdv6 View Posttranny downshifting? my DD does this too, but im pretty sure its just the tranny downshifting roughly
Could be a couple things.Originally posted by Zfenix View PostWell, when I stopped at traffic lights today with my foot on the brake, me car would run really hard and then there was a surge of power and my car kinda lunged forward. It was strange. Like I had let up a little on the brake and stepped on the gas pedal, but I didn't. Maybe it's a battery thing, like low power and then a surge of power. Or maybe the timing's off. What do ya'll think?
Did it only do it the one time? Or every time?
First guess would be a vacuum line (my new mantra for the week...lol...) or a TPS.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
My blue bird use to do that as well. Must be a problem with the v6's or something. No clue why it did it.
It did it about 2-5 times at each stop light, then it eventually stopped.Originally posted by 81DaytonaPaceCar View PostCould be a couple things.
TPS is good.
Vacuum line, hmmm? Well, what does that do?
The vac lines are all the smaller black rubber hoses running everywhere under the hood.Originally posted by Zfenix View PostIt did it about 2-5 times at each stop light, then it eventually stopped.
TPS is good.
Likely culprit would be one that attaches to the intake manifold.
If it's not repeating itself, it could be something as minor as a cracked line, or even one of them that doesn't get a good seal/attachment...it could just be not sealing briefly when the engine vibrates and the computer is now trying to adjust for the additional air it thinks it's seeing.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Originally posted by 81DaytonaPaceCar View PostThe vac lines are all the smaller black rubber hoses running everywhere under the hood.
OOOOOOOOOOHHHHH! Well, there was a clamp that broke. I can't tell you what hose it goes to, but it's at the top/front of the engine area. Kyle put a ziptie on it for the time, but maybe it's not as good as a clamp.
Could be...would have to see it...Originally posted by Zfenix View PostOOOOOOOOOOHHHHH! Well, there was a clamp that broke. I can't tell you what hose it goes to, but it's at the top/front of the engine area. Kyle put a ziptie on it for the time, but maybe it's not as good as a clamp.
Make Kyle come fix it...lol...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
if its a vacc line i highly doubt it could be causing any problems if its hooked on and ziptied, general tendencys will be to suck in to keep the hose on anyway.. Def isnt the tranny either if it did it several times at one light, my dynasty just lurches forward and jerks sometimes one good time when coming to a stop, must be a lil slow downshifting or something lolOriginally posted by 81DaytonaPaceCar View PostCould be...would have to see it...
Make Kyle come fix it...lol...-Derek-
I had this hapen to me in another car I used to drive, What it turned out to be was the number 4 cylinder rings went bad and the plug kept fouling out and missfireing. And this caused my car to jump and lurch at a stop, and it would do more them 1 time every time I stopped then go away and come back. just my experence with this type of problem. good lucksigpic
Robert Lawler
Your goto guy for non car related problems.
Yep...agreed...but frankly, we don't know what it could be at this point.Originally posted by redfbirdv6 View Postif its a vacc line i highly doubt it could be causing any problems if its hooked on and ziptied, general tendencys will be to suck in to keep the hose on anyway..
And I just want Kyle to get his sorry but over there and fix it...lol...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
No problem, just sharing what problems I've in the past.sigpic
Robert Lawler
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
The hose I put the zip tie on was from the intake tube to the valve cover so I doubt that it's that.
I'll check the TPS again, it's easy
See ya tomorrow
