My 91 firebird's been running rough. The idle isn't consistant and it stalls out ever so often. I put new plugs, wires, airfilter, oil, and it's pretty much the same (it needed all these anyway).
When I hooked it up to a scantool it ahd an EGR error message. Does anyone know anything about these?
I'm much more active on TGO as they have more info pertaining to my model, but I do stop by from time to time.
Whats the exact code number, There are sevral diffrent things that can cause an egr code,
1)The soliniod going bad-If you have a soleniod thats electronicly controled
2) The egr valve pintle sticking-most likely cause
3) your intake manifold is plugged/gummed up and the egr passage is clogged restricting airflow.
