Vacuum Lines
  • #31
    Originally posted by Syn View Post
    some cars i worked on were required to be opened so little that you can slip a piece of thin paper under the blade
    pull your iac check it for carbon build up as well
    Yeah, I think I need to push the screw in more, so it's not out so far.
    Sometimes when I start the car, it'll fire up, but then the idle will drop down low for a second, then go back up to normal.
    Getting the IAC out is a *****. I'll do it when I get the coolant bypass mod done.
