Stronger?
  • Stronger?
    9 or 10 bolt? which is stronger for the turd gens.
    9 inch?
      No, he's talking about the Borg Warner 9-bolt.
      Here's a good thread I found: http://www.hotrodders.com/forum/f-bo...0-a-58087.html
        hm..
          How much power are you thinking of putting out?...
            They both suck
              Quote:
              Originally Posted by JoeliusZ28
              10 bolt - 'tehn-bowlt' n - GM production rear axle for 160hp [maximum] S series minitrucks, however a moment of delinquency placed them in a 345 hp F-body. 10 bolts are easily confused with dead logs ande/or firewood, as they have similar strength and appearance properties. Unfortunately, 10 bolts are not flammable and therefore useless.
              James is right they both suck.
                they both suck, but that being said ive beat on my 10 bolt enough that i have some faith in them.
                  There's lots of guys running 89 TTAs in the 10s with the Borg Warner 9 bolt.
                    10 bolt blows.
                    James, since you got that fancy-schmancy engine, what rear end are you running?
                      Auto is your friend, 10bolt and an auto is not a horrible combo(not best combo... ). its those guys launching hard with sticky tires and those M6's!
                      just a bolt-on Lt1
                        I have found it to be wheel hop actually is what kills them quick.
                          wheel hop is deadly indeed!
                          just a bolt-on Lt1
                            yeah wheel hop sucks..
                              Is wheel hop when you launch hard, or when you are cornering and gain and lose traction every .5 seconds, over and over till you get straight?
