wheel questions
  • #31
    Ah okay.
    Well the thing is I'm thinking 17's are not going to look that much bigger then my current wheels...
    • #32
      Here is the tire dimensions
      Size ............. 245/50-16 .... 245/40-18 .... 255/40-18 .... 255/45-18
      SW Hieght ........ 4.82 ............ 3.86 ............ 4.02 ............ 4.52
      width ............... 9.65 ............ 9.65 ........... 10.04 .......... 10.04
      diameter .......... 25.65 .......... 25.72 ........... 26.03 .......... 27.04
      Speed @60 ....... 60.00 .......... 60.16 .......... 60.89 .......... 63.57
      Use this to help you with tire sizing. http://www.discounttire.com/dtcs/infoTireMath.dos
      • #33
        But you didn't do the 255/45/18's he was mentioning since they didn't list 255/40/18's as an available size where he was looking.
        Wade
        • #34
          I added it the post.
          • #35
            I figured they'd be over an inch taller than stock size. That's enough to throw off your speedo readings. On a computer controlled car(ie 4th gen) it can throw off your shift points as well as your speedo and mess with the ABS too.
            Wade
            • #36
              Yep, by 3.57mph to be exact.
              • #37
                You need more work to do Gary!!! Actually you just need WORK to do!!! I swear you just sit there and surf the web all day!
                Wade
                • #38
                  Hahaha you guys are great. Good info.
                  I'd appreciate it if someone could set up a pole for me..
                  TT IIs 17's or Chrome Irocs 18's
                  • #39
                    Poll Added
                    • #40
                      Thank-you sir.
                      • #41
                        bump the vote!
                        • #42
                          ****stock 16" rims****
                          ****17" TT2's****
                          Yeah theres a difference.
                          • #43
                            lmao.....guess what rims I voted for???
                            • #44
                              meh go with the irocs.. TTII's are as common as mcdonalds.
                              • #45
                                Does the size of your rims and tires affect your top speed, or acceleration?
