wheel questions
    Not a fan of Nexen tires or other Korean cheapo tires. 4.5" backspacing is the right backspacing for 8" wheels
    Wade
      yeah I paid $1550.00 out the door for mine. Rims, Tires, Lug nuts, locks, and chrome valve stems with caps.
        thanks for the info guys
          One more question, which tire would you guys use?
          225/40/18, 235/40/18, 245/40/18,
          225/45/18, 245/45/18 and 255/45/18
          The bottom three choices add $60.00 dollars total, but I wouldn't mind. Like I said I want the best.
            245/40/18 is the correct size
              What is yours sitting on Sean? I was thinking the widest they could come because I'd like a little more traction.
                Anyone else? What tire combo looks good or what would the benefits be?
                I was thinking getting the 245/40's up front and 245/45's in the rear, does that make sense?
                  i have 245/40's all around but i may be widening my rears to 9.5's to run 285's
                    Why do you want a taller tire on the back? They need to offer a 255/40/18 which would fit and be only slightly taller than the stock 245/50/16's and be a bit wider.
                    Wade
                      Oh my bad, I keep forgetting its width x height !
                      Probably just go the 245/40's all around.
                      What about the 255/45's for the rear? or would it stagger the stance to much and look stupid?
                        The 255/45's are going to be taller as well as wider. I'd have to look up specs to see just how much difference in height there is between a 245/40 and a 255/45. It'll give you some rake but there won't be any rotating tires if they are directional and if they aren't you can only swap side to side.
                        Wade
                          Huh, thanks for that info. Didn't think of that. Aren't the numbers in millimeters? So the rears would be 5mm's taller?
                            just get the same size all around so u can rotate..
                              The width is in millimeters. The sidewall is the percentage of the width. So a 40 series sidewall is 40% of the width of the tire, which in this case is 245mm.
                              Wade
                                Originally posted by 86Camaro View Post
                                I found these...
                                http://cgi.ebay.com/ebaymotors/18-IR...spagenameZWDVW
                                720.00$ delivered no rubber.
                                4.50" backspacing, does that work?
                                I can't believe they are sooo cheap right now.
                                http://cgi.ebay.com/ebaymotors/18-18...spagenameZWDVW
                                1280.00$ delivered with rubber. 245/45/18 and 255/45/18 rears
                                560.00$ for rubber is a decent price isn't it?
                                it depends on the quality of the tire. thoes arent a very expensive tire.. and they aren't very wide either. i'd look into a 17x9.5 so you can put a 275 width on it.
                                ~Phil
