i have a stock 305 with 4 barrel carb in my car and everything is hooked up and working but i cant get it to start. it turnes over and fires but will not actually start cant figure it out so i could use some help.
thank you
my dad and i figured it was the distributer but i have reset that thing in there a few times made sure it all lined up with the 1st piston made sure the piston was at the top of the cylinder. how else do you play with the timing.
ok i can do that i know the engine will run with a little bit of playing with it but i was not sure what to mess with. the engine ran strong but i changed the intake and carb from a 2 barrel to a 4 barrel
you said the rotor is lined up with the #1 piston. Do you mean the #1 plug wire on the cap? Some mopars you point the rotor towards the #1 piston but not on a SBC
