Originally posted by WMCC Gary
View Post
Project 3rd gen
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
Got a couple suggestions for you, do what you want with them
If you want to go with a 4 speed try picking up a 2004r if you can. they were the predecessor to the 700r4, reason they're better, all steel internals vs the 700's aluminum. However, if you aren't going to be on the highway much, eh, 400 should be fine, even a th350.
For your Vortec heads, not sure how much you are planning to spend total with doing work to them but there's a company called Racing Head Service that sells their own version of Vortecs. If you were to get RHS iron vortec bare heads, add the valves and springs you need and you'll be into a vortec style (better casting than the GM junk) with all the mods you would 'want' in a vortec and not much more than the GM price. Plus the RHS casting is almost 3 pounds more material than the GM casting. (beefed up in the areas the GM castings crack)
http://www.racingheadservice.com/Inf...rtec-Heads.aspPro Torker™ Vortec heads flow 27 more cfm at 0.500” lift -right out of the box.
Pro Torker™ Vortec heads come standard with radiused, hardened exhaust seats, multi-angled intake seats, and “Fast Burn” 64cc combustion chambers. To ensure maximum versatility, Pro Torker™ Vortec heads feature dual pattern intake compatibility to allow use with virtually any intake manifold, early or late. Also equipped with 1.550” valve spring seats and valve guides engineered to avoid retainer to guide clearance issues when used with high lift camshafts, Pro Torker™ Vortec heads have overcome all of the shortcomings normally associated with OEM Vortec heads.
Again, just a thought, might be worth checking into. I like that you can run a regular intake with them instead of being stuck buying and running a vortec pattern intake.
Thanks for the info, yeah im' not sure what im doing as far as heads go right now i don't have thousands to put into the car but enough to beef it up from last year.Originally posted by Orange Terror View PostGot a couple suggestions for you, do what you want with them
Agree with everything OT said there...RHS does have a nice product.Originally posted by Orange Terror View PostIf you want to go with a 4 speed try picking up a 2004r if you can. they were the predecessor to the 700r4, reason they're better, all steel internals vs the 700's aluminum. However, if you aren't going to be on the highway much, eh, 400 should be fine, even a th350.
As for the trans...both the 700R4 and 200R4 are nice for highway cruising...I think a TH400 is overkill...
But if you want to save some budget, I'd just go with a TH350...might be all you need...
Just my .02...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Well im looking for a 4 speed with overdrive to bring my r.p.m's down because i go on alot of cruises and im' running high r.p.m.'s so i want to give the car more power but better milage on the highway, especially if you guys want me to travel to the meet and greet.Originally posted by 81DaytonaPaceCar View PostAgree with everything OT said there...RHS does have a nice product.
Just my .02...
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
???????????????????????????/Originally posted by Orange Terror View PostWhat ratio gears are in the rear?
he wants to put in my 3:73's but we think not sure that he is running 3:42's
wants 3 spd for the track but 4 spd for the rd at a sensible price. this is a nice budgeted build that has been getting a little more done every winter the only prob is that he drives it all summer and stores his probe for winter use only. cant really afford to put 2 cars on the rd at one time and in this day and age im starting to fall in line with that cept for the amount of money wraped up in the ride.
Thanks Todd. Im just trying to stay relaxed and hope everything works out i look at it this way if its not out this summer ohhh well. Im not going to let this project stress me out i have enough shit goin on in my life right now that are more important than this car.Originally posted by tenpin842 View PostYeah 1 thing at a time. Best of luck.
