I cant figure out whats wrong with my headlights. They will be on for like 5 minutes and then go out and the come back on for a few seconds and back out. I checked the connections on the rear of the lights and they seem to be on tight. This would even happen when the car is sitting still and not running. Needless to say I cant drive at night.
Thanks in advance for the help.
The only thing that comes to mind is a short somewhere.
Check the fusebox just to make sure everything is seated as it should be.
Been there done that. I was thinking it was the light switch, but the the rest of the lights would go off also?
Depending on the year, interior and exterior lights are on different lines.
So, not necessarily.
Mine had a similar problem with the head lights. Problem was the plug was melted a tad bit so it wasn't getting a solid connection. So I would try wiggling the plug a little and see what happens.
