Can't wait to see the After Pictures.
The before pictures looks like the car was stored in a coal mine.
Currently Owned F-Bodies
1994 Firebird 3.4L V6 SPI, T5, Black with T-Tops and Leather Interior (Daily Driver) 1985 Trans-Am 383 Stroker Carb., Black with T-Tops (Hobby Car) 1986 Trans-Am 5.0L TPI, Blue with T-Tops. (Project Car)
You'd better get that hunk of junk TH350 working before thanksgiving so we can lay some rubber when im back.
I love a good 350 Turbo Trans on the Expressway... Nothing sounds better than a V8 tacking 4K at 70MPH.
I know.. Off topic.. But damn I missed my over driver when I ran a 350 for a while.
Hope to see those pictures of the new Engine soon.
sounds like its coming along - check vacuum lines and kickdowns also in case you disco-ed anthing in the change out?
Yep checked those already, they were fine. I was told to check the governer before I mess with the shift kit. I'm thinkin' something is f'ed up with the shift kit. Gonna go take some pics right now so I'll have them posted later.
350 Small Block Chevy Bored .030 Over (355) GM Performance Parts Vortec Heads Holley 650cfm Double Pumper Edelbrock Performer-Plus Cam Edelbrock Vortec Performer RPM Hedman Hedders 1-5/8" Long Tubes 2-1/2" Exhaust With "H" Pipe & Hooker Aero Chamber Mufflers TH350 With B&M Transpak Shift Kit & 2400rpm Stall B&M Tork Master Converter
Didnt you install an adjustable vac modulator? Maybe thats wayyy out of adjustment.
just so you have a place to start just bypass the vacume modulator for now or cap it off...and run right from the trans to the intake... when i first bought my car it kept shifting at 5,800 rpm even at slow speeds took forever to find the tiny little pin hole in my trans vacume line...the 5 bucks for all new vacume hose is almost as good as a bottle of asprin... just so i didnt have to think about it anymore
Finally got some pics. It's alittle dusty and the pics are blurry, but gives you an idea. Hoses, and wires and just kind of wherever right now. Underneath of my hood is pretty dirty, I have to clean that yet.
The Chrome is my choke knob.
And temp mounting of my gauges Mechanical Analog Oil Pressure & Water Temp
