Started The Cam Install...
    Originally posted by 99TransAmWS6
    Thats sweet. it lifts the lifter right off the cam when you slide it in? Are those holes normally open or do you have to remove plugs in the block?
      Yep holds the lifters up. No plugs to remove.
      1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
      Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
      2015 Silverado 2500HD 6.6 Diesel
      2010 Corvette Z06
      "The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
        yeah, Tom what you do is after the rockers are off and the push rods are out, you throw a few bolts in the cam and spin the cam nice and hard a few times and the lifters will stay up because the lifter tray holds them up, then you slide the JPR tool in which is just a metal dowel with a flat spot that holds the lifters in place so that they don't fall. the lifter tray holds the lifters up, the JPR tool is just an "incase the lifter tray doesn't work" they hold them up so they can't fall....
        the driveshaft thing is what i was saying was another option last night, just stick a pry bar between the yoke at the end (since whether you get a new driveshaft or keep the stocker, you'll need a 1350 (i think) yolk for the 9")
        1998 Camaro SS Bullseye Turbo
          How hard is it just to take out the lifters? I know a LS1 and even a LT1 are both different then my 87 305. But I just took all my lifters out. I did however have to take out my spark plugs to thread a tool in to force air in the cylinders when I change my valve springs and valve seals, so my valves wouldnt drop down. Sorry for asking a dumb question.....I just never did any kind of work like that to a 4th gen motor before.
            i was wondering, Even though i have the tool...do i still have to pop my valve covers off and pull the pushrods? I really hope i can just turn the cam and slide the tool in slowly. I already have the pushrods and springs installed. I dont really feel like having to take all that shit off again.
            2010 Corvette Z06
              i have no idea about LT1 motors as those are ancient now a days, but as far as LS1's to get the lifters out completely, you must remove the heads.
              You have to pull the rocker arms off, and pull the push rods out because leaving both items in, the valve springs will be pushing on the rockers, the rockers pushing on the push rods, and the push rods on the lifters, you DO NOT want any sort of force or pressure on the top of the lifters or else they can fall down and some will make it to the pan, others will get caught between the rods and crank, some will get jammed in other convenient places that are extremely hard to get to (ask me how i know)
              you would not be able to just "spin" the cam with the push rods and rockers on...the valve springs aren't that easy to compress while just spinning the cam by hand
                i figured. SOB..just another thing to do. Damnit lol
                2010 Corvette Z06
                  i think you have remove the heads to do lifters on both LT1 and LS1
                    cant you do it with just removeing the intake. and rockers. and leave the heads on
                    1995 TA Sold. i sure do miss it though.
                    1998 Trans Am aka Winter beater
                      Yeah.
                      On SBC and lt1, you have to take the rockers loose and pull the intake. You can reach down into the valley and pull the lifters out.
                        Originally posted by MattODoom
                        Yeah.
                        Thats what i have always done
                          ls1 is the only one you have to pull the heads to get the lifters out.
                          the lifters are between the small row of studs and the second row all of which is under the head.
                            ^ I see you might like to fish?
                            Do you ever go out on oxbow lake?
                            when are you taking me out? lol
                              hehe I fish about 3-4 times a week. I tournament fish too
                                Yeah.
                                yep, easy as pie
                                1996 CAMARO Z\28 M6
