Engine light codes?
  • Engine light codes?
    Can someone tell me what this means in English.I'm not a mechanic.
    Your shits broke?
      Nope not yet.lol
      Runs like normal just had the service engine soon light come on this morning
        Looks like both codes are the same issue but I'm not sure.I'm not a mechanic
          AIR pump is not kicking on for some reason. P0418 is an electrical test, P1418 is a physical test (monitors exhaust via o2 sensor)
          Check fuses, check wiring from relay to the AIR pump.
            Well,
            I located the fuse under the hood than I got in to go get a new fuse cause I'd figure I'd start there.
            The light was gone and I did not pull the fuse out.just took the lid off the fuse box to look at what it looks like.
            What now
              I'm not sure if its got anything to do with it or not but it has been raining here and I was driving in the rain when it came on this morning
                I would replace the relay for the AIR pump. All the AIR pump does it shoot air into the Cats to warm em up faster. So you don't have to worry.
                Put a new relay in, check the electrical connections to it, and then have the codes erased.
                  Could have something to do with it.
                  DTC's have a few ways they will clear themselves. One is by a scanner, which Autozone is not allowed to do. Another is if the fault is no longer persistent after 40 cycles, this is more so for high or low sensor readings from what I've seen. The other, and I can't say for sure, is that the light likely went off because it passed the test (pump kicked on) and removed the DTC.
                  P0418 and P0418 are MIL on 2 type codes, meaning they can fail once without the light coming on. If the test fails again on the next start, then it's not happy.
                    I started the car several times to see if it was gonna come back on and it hasn't.yet
                      Just go about driving the car normally then. If it comes on again, and it's the same thing, just check the relay and electrical connections. Also, don't start the car multiple times in a short amount of time either, or you can foul out the spark plugs and it will start to misfire. It happened to my grandfather's Corvette.. and they were not fun to replace.
                        Ok.Thanks guys
                          Orrrr... Just delete the emission control junk..?
                          1997 Trans Am
                          T56 swap. LS1 Cosmetics
