The bar that runs across to the other side with the 3 bolts in that mounts in the hole about the panhard bar do you have to leave that on with a ajustable panhard bar. 4th gen camaro
panhard bar question
Leave it alone. I have removed a lot of weight form my car and I left it there. It ties the rear frame rails together and I think it helps hold the gas tank up.Originally posted by mazakman View PostThe bar that runs across to the other side with the 3 bolts in that mounts in the hole about the panhard bar do you have to leave that on with a ajustable panhard bar. 4th gen camaro
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
Yes sir that bar stays in.
You can see I have an adjustable panhard bar and that bar is still in.
Now they make a tubular one if you want to run like 3in exhaust over the axle.
DSCN0204.JPGOriginally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
