what upgrades are need
  • what upgrades are need
    hey fam im planning on starting my rebuild in a month or so.... im just wondering what other supporting things should i do... lookin to put 400 hp to the rear wheels... full rebuild prob bore to 355, new cam, 3000 stall, poss trans cooler....btw just had trans rebuilt 4000 miles ago i have all the bolt ons headers cai t-body by-pass.. 1994 camaro z28 220xxx on the body
    This is an LT1? Are you set on 400?
    I'm sure you'll be happy with a little less. The LE and AI kits are becoming very popular and will probably net you 350-360 without getting into pricey heads. It's just tough to get those numbers through the automatics. [MENTION=254]JoeliusZ28[/MENTION] has one of these builds but with a M6. [MENTION=193]meissen[/MENTION] has a mild 355 that makes about 325 I think.
      If you even get close to 350+ HP at the rear wheel your going to have to consider rebuild on the rear end. I don't think stock rear would hold the HP especially with 220,000 miles on the clock.
        With that many miles, yes.. I would probably work my way back to front. Dont neglect suspension components either, I'm sure those need a good replacement.
          I'll save you time and money. Just give me $5,500 and your car and we'll call it good
          http://www.mifbody.com/vbulletin/sho...ghlight=mcalus
          [MENTION=3325]gasman[/MENTION]
          2002 Z28 Camaro A4
          1993 Z28 Camaro M6- SOLD
          1999 Z28 Camaro M6- SOLD
          2008 Ford Fusion SE - DD
            ^^ And you would be much happier unless you have some extreme sentimental value to your current camaro. Buy his, and keep the camaro in the mifbody family
              Lol thanks for the offer but mine has t-tops and is an auto. ... lol cant drive a m6 that well ill end up needing a new clutch by time I got it home ...
                Ok guys here is the deal I got roughly 4k to put into my car this year... im trying to get the best bang to the buck... the car runs ok starts up no smoke no leaks sounds good shifts good just doesn't have the balls it should. ... like I said it has 220xxx on the clock so I know it needs to be freshened up.... dont really know where to start???? Can someone plz point me in the right direction .....
                  @gasman
                  I dont know why you are trying to push this car so much. Just PLEASE KEEP THE THING ALREADY! Or wait until I can buy it.
                    nonsense!
                    How much coin are you looking to drop? It may not smoke now but when you start driving it like it should be driven you'll have issues. My advice, do it right the first time. Call lloyd elliott or advance induction. Tell them your goals.
                    Get ahold of a reputable machine shop. Expect to pay 800-1400 for a nice stock (.030 rebuild on your bottom end. You'll need new rings and pistons, bearings, cam, freeze plugs, arp rod and main bolts etc.
                    At that power level you will probably be close to maxing out your stock injectors. Also is it a stock fuel pump?
                    Things just keep adding up. Plus the while you're in there stuff. Oil pump, White spring mod, starter, rack, also Suspension.
                    You have my number feel free to text me any questions. I'm far from an expert but...
                    not trying to discourage you just trying to help you know what to expect cost wise.
                    I need to be back in an lsjuannnnnnn!
                    2002 Z28 Camaro A4
                      nonsense, just add some spray and be happy. Or heck have two, lots of people are doing it!
