Pictures won't really help you out there...you need to get under the car and look at it 3 dimensionaly.....there will be stuff in the way that you can't tell from a picture.
Heres a 4g with duals and X - also note the trick cutout spots
Thanks Matt,
I am going to make a set of custom side exit exhaust pipes as part of my winter projects. The underside pictures will help me photoshop my design. I will still be looking at the underside in person when checking for clearance.
really the only way to make yourself a "custom" exhaust is to get a few strait, a few 90* turns and a few 180* and maybe a few 45* and get under your car and just start going where you want, while chopping the pieces along your way and tack welding them inplace, then take it down and weld it all up
you'd probably be better off finding a nice cat-back and throwing a cutout in it if that's what you're after
I'm not shure what you heve for a exhaust now I'm guessing stock but a nice cut out sound sweet I just had one put on and it sounds great. I have QTP headers and Y and put my cut out just after the and it sounds verry nice. And when I want the sound leavel down just flip the switch to close the cutout.
01 SS 224/224 114 thunder cam(springs,rods,retainers) 3200 stall, 3.73's, under drive pully, transgo shift kit, QTP race headers and Y, QTP cut out in I pipe and M/T drag radials.
best et 12.23 60 1.67
