Originally posted by 1BADAIR
View Post
More 4L60E issues.
When I took the sprag apart there was a lot of shrapnel, looks like you threw it all in a blender. I am glad that it is enclosed, so all of that crap cannot circulate.Originally posted by hoogiesngrinderz View Postbeing able to hit 3rd and 4th by manually shifting is weird! A bad sprag wouldn't allow any forward movement in those gears regardless of how it got there...and it sucks you had to tear it down againLast edited by jderry; September 18th, 2013, 10:15 PM.sigpic
1996 Base Model
+2 cylinder mod
The car didn't seem to hook as well in the middle hole, I also have an adjustable torque arm relocation bracket, but that is in the "stock" position. Pinion angle is about -2.5 degrees right now. The rear LCA angle looks to be about -3.5 degrees in the bottom hole.Originally posted by 1BADAIR View PostLook at the pic and compare rear separation to when sitting still. Some is ok. Not much. If stock height move it 1 hole. The angle should be very little to the axle . To much angle will hit the tire , shove it into te ground and actually bounce the tire back up. Think nocooler has a vid of his doing it.
You are probably right. After some research, there is about 5 lbs difference in the spring rates. Which should not do too much of anything.Originally posted by c0ncEpT View PostI'm pretty sure thats a myth and if anything they are just making up for lack of an actual working suspension.sigpic
1996 Base Model
+2 cylinder mod
If you have stock springs in the rear, even with a heater hose mod you probably want to use the top hole in the brackets. Use an angle finder, thats where i have mine with 3/4" drop spring and isolator still in place and its perfect.-Joel
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Looks like it still had a few elements intact, could explain why it held during cruiseOriginally posted by jderry View PostWhen I took the sprag apart there was a lot of shrapnel, looks like you threw it all in a blender. I am glad that it is enclosed, so all of that crap cannot circulate.
Was yours a 26 or 29 element?
The one I broke was 29 elements, with a single cage.Originally posted by hoogiesngrinderz View PostLooks like it still had a few elements intact, could explain why it held during cruise
I installed a borg warner dual cage unit last night.
What angle is ideal for drag racing?Originally posted by c0ncEpT View PostThe further downhill the bar is running the harder it hits the tires but the faster it will unload too.
I tried the top hole, it didn't feel as good as the it does in the bottom.Originally posted by JoeliusZ28 View PostIf you have stock springs in the rear, even with a heater hose mod you probably want to use the top hole in the brackets. Use an angle finder, thats where i have mine with 3/4" drop spring and isolator still in place and its perfect.
What angle are yours at now?sigpic
1996 Base Model
+2 cylinder mod
Thats the aggravating part, it just got rebuilt 31,xxx miles ago by aamco transmission. I was sceptical from day 1 then start experiencing problems in warranty that satisfied the symptoms of torque converter shudder then within this last month it slowly but surely broke apart. exact symptoms as yours. ill never ever go back to aamco. im buying a built one now. swapping one a built one will be much more worth it.Originally posted by jderry View PostHow many miles on your trans?
I have heard some bad stuff about their build too.Originally posted by 95z28 View PostThats the aggravating part, it just got rebuilt 31,xxx miles ago by aamco transmission. I was sceptical from day 1 then start experiencing problems in warranty that satisfied the symptoms of torque converter shudder then within this last month it slowly but surely broke apart. exact symptoms as yours. ill never ever go back to aamco. im buying a built one now. swapping one a built one will be much more worth it.
The built trans idea is a good one.
I am saving for one nowsigpic
1996 Base Model
+2 cylinder mod
Keep in mind too much angle might feel better on a part throttle launch, but a full throttle or stalled up launch could hit the tires too hard and it will kick itself away from the ground. I agree with mike, 1.5-2 degrees is ideal. Thats where mine is and it launches flat pretty much all around.Originally posted by jderry View PostThe one I broke was 29 elements, with a single cage.
What angle are yours at now?-Joel
