What is the best way to get control arm bushings out?
Bushing removal
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Pretty much this. You can drill a bunch of holes into the rubber then burn them out, but a 20 ton press will make it a quick job. Sometimes scary when they let go!Originally posted by 93formulalt1 View PostDo you have access to a hydraulic press? If so, that's by far the easiest way. Any other attempts will result in frustration and anger. haha
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Frustrating road ahead.
I've had my 20 ton press jump off the shop floor when they pop. I should probably bolt it to the floor
