Well im do for an oil change just came up to the mark, but my low oil light came on so i pulled over and checked the oil and it was about 1 1/2qts. low. is it common for the ls1 to consume that much oil? i checked for leaks the motor is dry as a bone.
Oil Consumption?
Oil Consumption?
A convoy of imports= Alot of unessary noise
Master ASE Certified
Master State Certified
Master State Motorcycle Certified
GM Certified
Winners Powersports -
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
Yes, I found this same thing out shortly after I bought mine as well. It has to do with the PCV system. 4000 RPM's is the key. Basically, the more you have the RPMs above 4000 the more you'll use. I go through an extra quart or 2 per summer. I've just gotten into the habit of checking it every time I put gas in and I keep a quart in the back.Originally posted by 01SunsetWS6Well im do for an oil change just came up to the mark, but my low oil light came on so i pulled over and checked the oil and it was about 1 1/2qts. low. is it common for the ls1 to consume that much oil? i checked for leaks the motor is dry as a bone.
There is a way to eliminate this or upgrade it, however I'm not familiar with it. But I'm sure if you search LS1tech.com its there.
Thank you once again you have awsered my question!
i have been driving it pretty hard this last week or so. That probally helped out then
GM Certified
Winners Powersports
It is common. Just pay close attention to it. Ill have to look for the write up on the pcv valve..i know what your talking about OT.1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
2015 Silverado 2500HD 6.6 Diesel
2010 Corvette Z06
"The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
Thanks all, 1badair where did you get the catch can at?A convoy of imports= Alot of unessary noise
GM Certified
Winners Powersports
thanksA convoy of imports= Alot of unessary noise
GM Certified
Winners Powersports
