Oil Consumption?
  • Oil Consumption?
    Well im do for an oil change just came up to the mark, but my low oil light came on so i pulled over and checked the oil and it was about 1 1/2qts. low. is it common for the ls1 to consume that much oil? i checked for leaks the motor is dry as a bone.
    A convoy of imports= Alot of unessary noise
    Master ASE Certified
    Master State Certified
    Master State Motorcycle Certified
    GM Certified
    Winners Powersports
    Yes, I found this same thing out shortly after I bought mine as well. It has to do with the PCV system. 4000 RPM's is the key. Basically, the more you have the RPMs above 4000 the more you'll use. I go through an extra quart or 2 per summer. I've just gotten into the habit of checking it every time I put gas in and I keep a quart in the back.
    There is a way to eliminate this or upgrade it, however I'm not familiar with it. But I'm sure if you search LS1tech.com its there.
      Thank you once again you have awsered my question! i have been driving it pretty hard this last week or so. That probally helped out then
      GM Certified
      Winners Powersports
        It is common. Just pay close attention to it. Ill have to look for the write up on the pcv valve..i know what your talking about OT.
        1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
        Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
        2015 Silverado 2500HD 6.6 Diesel
        2010 Corvette Z06
        "The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
          you can get the truck restrictor(replaces the PVC valve)
          change to the Ls6 valley cover (requires notching some blocks)
          or get a catch can like me
            Thanks all, 1badair where did you get the catch can at?
            GM Certified
            Winners Powersports
              accurate machine works
              the price has gone way up though.
              greddy and others have some that work
                thanks
                GM Certified
                Winners Powersports
                  Are you hearing any of the cold piston slap noise from it?
