Hey guys just did my timing cover gasket and im not sure why im experiencing some of the weird issues im having, any help would be great. My fans arent turning on at all. I'm getting a low rpm vibration or shake around 1500-2000, i think it possibly is my exhaust but i still have to look at it. Sorry for such a short log but if anyone sees anything ill gladly do another log. log 2.uni
did you get harmonic balancer reinstalled correctly? Opti spark correct and are wires going to correct plugs?
Well I got a small leak from what it looks like the bottom seal the hub goes into. So no matter what ill be taking it off again. But what do you mean correctly? I just knew that everything needed to be lined up at 12'oclock and I torqued everything to spec.
figured out the fan issue today. I bough a new temp sensor and it was DOA apparently so went back to o'reillys and grabbed another one. all is good with that.
