Went out 30 min or so ago. Hit the key and it started. The problem seems to be gone. But I'll swap the icm and try that
1993 camaro z28 project thread
shhhhhhh!!!!!tttt
Its even bigger now because I knocked out
All the soft spots. Its roughly 12 wide and 14 long.
I haven't checked the other side yet.
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
With an area that bad you are looking at finding a donor car or spending the money on new pans. You could find a metal fab guy to fix it but it won't be any cheaper unless he doesn't value his time.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
That's one way to do it, but it would bug the shit out of me knowing it's there
I'd say $1500 minimum for pans and labor to make it right.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
No, 20 minimum.Originally posted by 9302z28SS View PostYou think 26 gauge steel is good for this patch? Its zync plated
Yikes that's one big hole. Unfortunately it's rather common on our cars.- Brian Meissen
Welp patched it by doubling up the 26 gauge steel then pop riveting it to the floors. Worked like a charm. They're solid as a rock.
Also found me a 150mph speedo with 40k miles on it. Paid 30$ and got a brand new white faced led overlay. Can't beat that. The overlay alone is 60$ on eBay. Cluster is 125$
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Good to hear. I'd recommend using seam sealer down below for the time being. Blend it well and undercoat so it doesn't stand out - but please disclose the issue if you sell the car
Nobody likes be chased down by a guy with a baseball bat.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Get the car right before jumping into an engine swap. It wouldn't be wise to plop in a hellacious motor when you can Fred Flinstone your car
A solid foundation should be priority number one.
