My trans am is hitting hard from 1st to 2nd while driving normal
It will come up and hit my trans tunnel like i need to replace the
trans mount.
So i replaced it and its still happening.
Checked my motor mounts and they dont seem to be bad but i did have a loose
Bolt, tightened it and it still does it.
I did check my tork arm and its missing the bolt in the rear
By the diff cover.
Could this be doing it?
I also have a shim between the trans and the trans mount
Could that be it? Its always hit. But doesnt do it as bad or ay all
Under load
trans mount.
By the diff cover.
Under load
That bolt is the only reason that the torque arm stays in the mount. Are you missing the mount and the left side shell as well?
