Gauge was tested with another gauge. Again, everything worked except the speedo. I am also suspicious of the correlation of cruise and speedo, but I wonder if the lack of speedometer is the cause of cruise not working since it engages over 35mph and the vehicle is not giving the PCM a reading. I think my next step is going to be rewiring from the VSS to the PCM to see if the wires are possibly frayed.
BTW, I have heard about testing the wires by making a circuit through them and connecting to a light bulb and power source. If the bulb is bright, then the wires are not damaged. If it is not bright, there is a problem with the wires. Ever heard of this?
