are you pulling the engine and trans or just the trans either way it very easy once you unhook everything i just did it . if you pulling just the trans make sure like ryan said to pull the clutch fork down off of the release bearing or it will get hung up i left the bell housing on the block then i removed that after the trans was out made life easyer thats for sure.
loosen the cap on the resivor and the just line up the slave with the clutch fork and push it in by hand that's how i did it a few times. by the way GM said that the master and slave should be replaced on every clutch replacement i now no why . if ya end up needing it the ws6 store has the gm unit for a $150 and they also sell the adjustable tick performance unit as well .
also the GM unit is complete and pre blead
