Your car is OBD1 if it's a 1995.
I'd take a minute to go through and recheck everything.
See if you're getting spark at the coil. (take a plug and put it in the coil to opti wire)
Check the schrader valve, see if you're getting fuel pressure at the rail.
Check the MAF, make sure it's facing the correct way and is plugged in correctly.
Rent a noid light to see if the injectors are being told to pluse.
