Anyone in the Troy/Rochester area able to lend a hand or give an opinion?
  • Anyone in the Troy/Rochester area able to lend a hand or give an opinion?
    Im at 18 n john r, i tore my intake off my car again because it was leakin oil so i guess i didnt seal it right in the rear, pulled intake off last monday now just got it all put back together today. First start was rough n didnt want to idle. after playin around with some things it started and idled but was rough, i assumed it was somethin with the MAF since i didnt have the intake tube on all the way. ended up gettin the car to start and idled without the rubber intake tube on it, took it around the block and all. get home put the tube back on and it once it was all plugged up it was idling a bit rough so i figured id unplug the battery for a few n see if itd reset. i hook the battery up and now it just cranks and cranks. ughhhhh. im goin out of my mind and am really frustrated. if anyone could come by n take a look itd be greatly appreciated!!!!
    1995 Firebird Formula (Sold but not forgotten)
    1998 Camaro Z28 LS1
    2003 Silverado 2500HD CCSB 4x4 6.6 Duramax (DD with minor mods for better "MPG's")
    2004 Trailblazer LT3 i6 4x4 (wifes ride)
    my cell # is (248) 918-1435 if anyone is interested
    1998 Camaro Z28 LS1
      is the arrow on the maf facing toward the engine?
        yeah
        1998 Camaro Z28 LS1
          check the injector harness?
          try unplugging the MAF?
            yes ive done both, unplugged everything made sure all connections were clean plugged everything back up still nothin. cranks all day long but wont fire
            1998 Camaro Z28 LS1
              pull a spark plug, see if its wet and if you have spark
                i did and i do have spark. im thinkin i may of bumped a sensor or something... but i rented an obd2 scanner from o'reillys and it wouldnt pick up the codes on the car...
                1998 Camaro Z28 LS1
                  was the plug dry? Do you smell fuel from the cylinder with the removed plug when you crank it?
                    The only thing that changed between it idling rough and not starting at all was unplugging the battery? I'd be looking at the battery. Is it a slow crank like the battery is almost dead? are you sure you have good connections for the ground?
                      Have you tried giving it any throttle at all when you're cranking?
                      2015 Silverado
                        plug was dry. it didnt smell like fuel but i can hear the pump kickin on
                        1998 Camaro Z28 LS1
                          i ended up killin the battery crankin it. left it on the charger all last night went out today and took it off, again it cranks just as it should its not a slow crank at all. i tried started fluid to see n it still didnt even act like it wanted to start
                          1998 Camaro Z28 LS1
                            yeah ive pumped the throttle held it wide open and not touched it at all. it is showing no signs of it wanting to start it just cranks.
                            1998 Camaro Z28 LS1
                              This scan tool i have is sayin it cant make a connection to the vehicle, i remember the same thing happened on my 95 camaro with a 3.4 v6 when i tried scanning it
                              1998 Camaro Z28 LS1
